Re: IH Wheel Weights
Posted by mkirsch on July 17, 2013 at 05:30:26 from (64.80.110.75):
In Reply to: IH Wheel Weights posted by Martin Miller on July 16, 2013 at 10:05:14:
Assuming you want to do it the "correct" way, with square-headed bolts:
How do you hold up 300lbs of iron, push the bolt through, and thread on a nut without a forklift or three NFL linebackers?
Doesn't the first set of weights use the four holes near the center of the weight, and the second set use the holes around the outside of the weight?
