Re: 1066 Black Stripe Hydraulic Remote Problem
Posted by mkirsch on July 17, 2013 at 05:35:07 from (64.80.110.75):
In Reply to: 1066 Black Stripe Hydraulic Remote Problem posted by 1130Leo on July 17, 2013 at 05:28:46:
The valves are under the seat.
I'm surprised it's not blatantly obvious, because the cover is usually missing on these tractors. People take them off to fix problems and don't put them back.
Anyway, remove the cover from below the seat, and you will be able to see the linkages from the levers to the remote valves. Move the lever on the one that works, watch what happens, and then compare to the lever that does not work.
Post what you find and someone will tell you what to check next.
