Posted by Nathon on July 17, 2013 at 09:31:49 from (216.227.55.31):
In Reply to: emblem pins posted by Steve43 on July 15, 2013 at 10:44:53:
First I tried to reattach a pin using the spot weld method. I am not that good. Then I took a piece of blue board insulation. I had one good emblem that I pressed down on the blue board. I then took a pen and marked the exact position of the emblem on the blue board. I removed the good emblem from the blue board and prepped my pinless emblem for JB Weld. I salvaged two pins from a junk donor emblem I placed them in the holes in the blue board. I put a dab of JB in the proper locations on the back of the emblem and then carefully located it on the marked area of the blue board. I clamped it down and went to bed for the night. Next evening vuala I had resurrected a $75 emblem. It fit well and I have had no issues.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
