Put your handyman jack under the axle housing and lift just enough to take some pressure off. As it lifts the housing look for relative movement between the axle and the housing. If there's more than 1/16th" movement a new seal won't help. That's a lot of play though and usually a new seal will do the trick. National 417316
The grease on the outer bearing is to keep it lubed when the other wheel is down in the furrow. On flat ground with the oil level full the outer bearings will be in some oil. Most likely the bearing is ok. Just put in a new zerk and carry on.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
