Re: farmall c float
Posted by gene bender on July 17, 2013 at 21:06:47 from (67.55.227.12):
In Reply to: Re: farmall c float posted by indiana george on July 17, 2013 at 11:42:43:
Sure you can blow some air thru those passages but they arent clean at the bottom of the passage. I have found you sometimes need to use a drill the size of the passage and turn it with your fingers or using a holder and too many times you will pull the drill out and find rust on the end of the drill bit it does need to be realy clean for the idle mixture to let the engine strt good.
