Re: 1940 Farmall M wiring
Posted by gene bender on July 17, 2013 at 21:08:26 from (67.55.227.12):
In Reply to: Re: 1940 Farmall M wiring posted by Central Illinois on July 17, 2013 at 21:04:06:
Great then you should still have a cut-out on the gen. Just make sure when you order a new harness to get one for a cut-out.
