Re: farmall c float
Posted by old on July 18, 2013 at 14:55:58 from (209.86.226.32):
In Reply to: Re: farmall c float posted by indiana george on July 18, 2013 at 09:14:53:
Ok so you have gas on your hands and good suction so check your spark it is likely to be weak and that means no start. Your spark needs to be a blue/white in color and jump[ at least a 1/4 inch gap. By the way if your plugs get wet that in turn cause a gas fouled plug
