Re: Farmall C Booster Seat
Posted by Janicholson on July 18, 2013 at 18:16:57 from (74.60.94.18):
In Reply to: Farmall C Booster Seat posted by cubluvn8n on July 18, 2013 at 16:28:35:
THe C is a little tougher than an offset to install a second seat. It is possible to do it, but the framework needs to be attached to the axles and be strong enough to support at least 3 times the expected load. The hexagon axle housing makes this even more challenging.
A safe and secure method to consider is a small utility trailer. It would be useful for many other purposes as well. Jim
