Ignition "ON", points "open", you should have battery voltage at BOTH low tension terminals on the coil.
Ignition "ON", points closed, you should have voltage at the "ignition switch" side of the coil and NO voltage on the distributor/breaker point side 'cuz that end of the winding in the coil is connected to chassis ground through the breaker points.
Whip out a test light and see what's going on on the points side of the coil with the points open, then with them closed, and post back.
If NO voltage on points side of coil with points "open", insulator at distributor terminal may be shorted, condenser may be shorted, or something else in that area that is NOT supposed to be touching ground may be out of place, and grounding.
To gain a good understanding of how Kettering ignition systems work, take a look at the John Deere FOS-20 manual for ignition systems.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
