Re: IH 1975 Cub, no spark past coil?
Posted by John T on July 19, 2013 at 04:58:07 from (216.249.76.176):
In Reply to: IH 1975 Cub, no spark past coil? posted by davidrz on July 18, 2013 at 20:34:11:
With the ignition on and voltage present on the coils high input (NOT to dsitributor) terminal, theres (if all is well) usually no voltage on the coils output to distributor BECAUSE THE POINTS ARE USUALLY CLOSED and thats grounded out....
If you put a test lamp on the coils output to frame and with ign on if you slowly turn the engine over the light should flash ON (when points open) and OFF (when points are closed) otherwise shes not gonna fire!!!!!!
So I dont have to re invent the wheel each time this question gets asked, which it is almost daily sometimes, SEE MY TROUBLESHOOTING PROCEDURE LINKED BELOW
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=5745
John T
