The 340 is the illicit love child of a Super C and a 460. It has an engine and front end heavily derived from the Super C, bolted to the rear end of a 460.
Fast hitch (rockshaft) was common, but optional.
Lever on the left side is the TA.
As far as preparing for a first start, you can go as simple as check the oil, add gas, hook up a battery, and press the button.
It wouldn't hurt to roll the engine through an entire revolution or two with a wrench on the front pulley bolt.
Once you do that, hook up a battery, pull the coil wire out of the distributor cap, hold the tip near the engine block, and crank it over a couple times. See if you get a spark. If not you probably need to file and reset the points.
You can pull the carburetor and clean it, or even rebuild it if you so choose.
Check the gas tank for varnish and excessive crud. Use an external gas tank of some sort if it's bad.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
