Re: IH 1975 Cub, no spark past coil?
Posted by mkirsch on July 19, 2013 at 05:15:14 from (64.80.110.75):
In Reply to: IH 1975 Cub, no spark past coil? posted by davidrz on July 18, 2013 at 20:34:11:
You should only get actual "spark" out of the center post on an ignition coil. The two terminals should have "juice," or more appropriately "power," which means that a test light will light if you connect it, or you will read voltage on a voltmeter.
If that's what you meant I apologize.
Have you pulled the center wire off the distributor cap and held it 1/4" from the engine block while cranking? No spark there?
Points could be glazed over, or set too close.
Did you change the condensor?
