Re: Farmall 656 Diesel-Hydraulic Issue, No Down pressure
Posted by farmallboy15 on July 19, 2013 at 13:11:33 from (172.243.36.179):
In Reply to: Farmall 656 Diesel-Hydraulic Issue, No Down pressure posted by KrisM on July 19, 2013 at 12:52:33:
I don't believe there should be down pressure on the 3pt only on fasthitchs. Not sure on the draft control. If there is a access plate under the seat like my 504 you can take it off and make sure the lever inside is moving right.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
