Re: engine specifications on H
Posted by Owen Aaland on July 19, 2013 at 16:52:35 from (216.47.33.130):
In Reply to: engine specifications on H posted by Janicholson on July 19, 2013 at 11:36:05:
To get a 123 up to a 135 also requires a change in crankshaft.
Standard bore for a 123 is 3.125". Oversize pistons and sleeves are 3.25, the same as the C135. However, the C135 also uses a crankshaft with a stroke of 4.0625 versus the 4.000 used in the 113 and 123 engines. Using the 3.250 pistons and the 4.00 crankshaft leaves you with a 132 engine.
There is also a C146 engine that was not used very much. It is basically a C153 block with a C135 crankshaft.
Bore and stroke for all the engines in this family are as follows:
C113 - 3.00 X 4.00
C123 - 3.125 X 4.00
C132 - 3.25 X 4.00
C135 - 3.25 X 4.0625
C146 - 3.375 X 4.0625
C153 - 3.375 X 4.25
