Like Owen said, you have a later style pto. They engage when the plunger goes down. It is locked in by a internal piston and ball mechanism in the valve so therefore you do not need or want an overcenter linkage. If the pressure is not up to snuff they will not stay engaged and also the pressure is not adjustable with the spool like the older style pto's. It has a separate relief valve inside the pto. Those relief valves have a fine screen in them that plugs up and then you don't get good pressure for engagement. The pto may appear to run fine but it just won't stay engaged. Of course, other reasons for low pressure also.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
