Re: f 20 flywheel
Posted by Tom Fleming on July 20, 2013 at 03:21:01 from (174.242.240.159):
In Reply to: f 20 flywheel posted by heavyhaulerto on July 19, 2013 at 20:03:15:
Well, if you don't have the original Greb puller, it has 3 short legs, shaped like reverse "Z". Also, they bolt into the face of the flywheel, you should see 3 holes to do so. Lastly, I wouldn't use any puller rated under 7 tons, preferably more like 10 tons.
Make sure you remove the key pin from between the flywheel and the crank. Lastly, my experience has been, this is NOT for the faint of heart. The 2 I have helped with let go with a bang that would "wake the dead"...........
Absolutely can be done, and with moderate effort..........if the right equipment is used.
