Posted by CNKS on July 20, 2013 at 08:10:26 from (216.144.104.128):
In Reply to: H engine weight posted by bmagee on July 20, 2013 at 08:00:09:
Yes but be careful. I put an M engine on a 1000 lb capacity stand and it had all it wanted. Biggest problem is that the front end of the engine has no support and is loading the cast bolt holes on the rear of the engine. I usually use a 2x4 to support the front end, remove it to turn the engine over and replace it. I used the same one for the 6 cyl engine from a 460, I think the M engine is heavier.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
