Re: Will an IH 2000 loader fit onto a 350 RC
Posted by mkirsch on July 20, 2013 at 14:50:06 from (67.253.161.186):
In Reply to: Will an IH 2000 loader fit onto a 350 RC posted by Brendon-KS on July 20, 2013 at 04:14:15:
Hmm, rear axle mounting should work, as the rear axle housings are practically identical from the 350 to the 460.
Main issue is the 460 is wider and longer in front. You can use spacers and longer bolts on the 350.
