Re: MW hand clutch operation
Posted by Nebraska Kirk on July 21, 2013 at 20:32:35 from (207.91.4.159):
In Reply to: MW hand clutch operation posted by BigTone on July 21, 2013 at 18:54:08:
The M&W hand clutch allowed you to disengage the left side final drive, thus stopping forward motion of the tractor without interrupting power to the PTO. This was the cat's meow for baling, combining or running a cornpicker where the tractor could be stopped without stopping the PTO and thus allowing the PTO driven implement to 'catch up'. You still need to use the foot clutch to change gears. The M&W clutch manual says the clutch should be adjusted so that it takes about 30 lbs. of pressure to push the handle forward to engage the clutch.
