Posted by John T on July 22, 2013 at 04:05:09 from (216.249.76.176):
In Reply to: 130 starting circuit posted by beatle on July 21, 2013 at 17:11:52:
On a Pos ground system the coils + (if wired right) connects to the distributor and its points and if you turn the ign, ON although theres is voltage over on the coils other - input, THERES "USUALLY" NO VOLTAGE ON THE COILS + AS THE POINTS ARE USUALLY CLOSED WHEN SHES JUST SITTING THERE NOT RUNNING. Sure if a piston just happens to stop at TDC on compression the points would be open, but that usually dont happen.
If you place a test lamp on the coils + to distributor terminal and turn the ign on and slowly turn the engine over, it should flash ON (when points are open) and OFF (when points are closed)
If you work through my Ignition Troubleshooting Procedure linked below it can diagnose the cause of no spark.........
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
