Re: Re: Re: Re: Re: FARMALL 130 12 VOLT CONVERSION COMPLETE
Posted by Bob M on November 26, 2000 at 07:14:38 from (172.138.92.133):
In Reply to: Re: Re: Re: Re: FARMALL 130 12 VOLT CONVERSION COMPLETE posted by ltf in nc on November 25, 2000 at 14:36:22:
ltf - I believe you are correct. So called "12 volt" coils have a different (higher impedance) primary winding inherent in the design. Makes it appear to the rest of the primary circuit like they have an internal resistor, but without generating heat inside the coil.
As far as points go, at low voltages (6 or 12 volts) they don't care much what voltage they see. What kills points is current. The ballast resistor a 12 volt system serves to reduce coil (hence point) current. This in turn extends both coil and point life.
Post A Followup
: Re: Re: Re: Re: Re: Re: FARMALL 130 12 VOLT CONVERSION COMPLETE
