Re: 300 belt pulley seal
Posted by Don R of Mn on July 22, 2013 at 12:25:23 from (184.229.197.8):
In Reply to: 300 belt pulley seal posted by Bkpigs on July 21, 2013 at 14:39:35:
If it is like a W9 pulley drive one of the bolts that hold it down will catch the inner bearing. Loosen it, lift it up and kick of to side, the fuel tank will not let you remove it all the way. The main shaft then should slide out.
