Re: 47 M Head and Pistons
Posted by Owen Aaland on July 22, 2013 at 13:52:06 from (216.47.32.133):
In Reply to: 47 M Head and Pistons posted by keithg on July 21, 2013 at 09:38:24:
At the very least the head needs to be pressure checked for leaks to be sure it is flat.
The pistons most likely are serviceable as the scoring doesn't look to be too deep. The greater problem is going to be the sleeves. If they are scored like the pistons you will not be able to stop it from leaking oil up and compression down. It is not going to be critical for a tractor that isn't going to be used for heavy work but it wont run like a new one.
