Re: Re: Found a Farmall H, with loader, what is it worth?
Posted by Bob R check out list on November 26, 2000 at 07:34:04 from (209.198.115.65):
In Reply to: Re: Found a Farmall H, with loader, what is it worth? posted by What to Checkout list..? on November 26, 2000 at 05:29:07:
It was for a M not long ago .
It would be good to hear it run .
If it starts good you've eliminated a lot of problems already . like the carb , ignition . starter ,ect .
Does it charge . Gages work ?
A compression check hot is great . You can pull one spark plug at a time (engine running)to see if you have a "dead" cylinder . A dead cylinder will not have an rpm drop when you pull the plug wire to that cylinder .
Can you drive it , check brakes . Clutch , gears .
You dont want grinding noises in the transmission .
Look at the cylinders for the bucket . Is the shaft pitted ? leaky ?
Others will add more
Post A Followup
: Re: Re: Re: Found a Farmall H, with loader, what is it worth?
