I put one on my Regular. When I took it apart to clean the bearing, the cage was already loose and came apart fairly easily. I would say, if all your rollers are good, do not take the cage apart, it can be cleaned just fine as it is. Letting it soak for a while will allow the solvent to do it's job in softening the old nasty dirty greasy crud and then it can be scraped and brushed off. My bearing had several badly rusted rollers so I bought some new 1/2" hardened and ground shaft, cut it into the correct lengths and made all new rollers.
The cage is comprised of 2 end pieces held apart with several pins. The ends of the pins are peened over to hold everything together.
This post was edited by Nebraska Kirk at 15:38:09 07/22/13.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
