Re: Farmall C - Leaking gear oil
Posted by Dennis K (WA) on July 22, 2013 at 17:18:16 from (24.21.78.195):
In Reply to: Farmall C - Leaking gear oil posted by C. Amick on July 21, 2013 at 16:21:10:
The lips of the seals, spring side, need to face the oil.
So, I would install the seal on the side you intend to slide the shaft in from, slide the shaft through the housing and install the opposite side over the shaft and then drive it into the housing with a piece of pipe or a punch.
If you try to slide the shaft in against the lip of the second seal you will probably damage it.
I would drain all of the oil and save a mess.
good luck
Dennis
