Re: Farmall C - Leaking gear oil
Posted by rhtx55 on July 22, 2013 at 17:31:06 from (68.185.207.25):
In Reply to: Farmall C - Leaking gear oil posted by C. Amick on July 21, 2013 at 16:21:10:
One trick I had to learn the hard way, is use some typing or copy paper, or masking tape to cover up the keyways on the shaft when you re-install it. Sliding the sharp key ways on the shaft through the new seal will cut them & they will leak like a sieve, & (don't ask me how I know this) you will get to replace them again. Good thing is by the second time around you get very efficient at removing & installing them ....
