Re: H CRANKSHAFT
Posted by D Slater on July 22, 2013 at 17:54:31 from (184.14.164.10):
In Reply to: H CRANKSHAFT posted by S2710 on July 22, 2013 at 17:00:34:
Yes just use the bearings in the size needed for use with late H, SH, or 300. Late H through 350 crank diameters are bigger than most H tractors. Bearings are thinner so they fit the H block and rods and 300 crank without any other changes.
