IH 424 fuel issue
Posted by Michael Sheik on July 22, 2013 at 19:09:03 from (64.250.203.233):
I have a 424 gas tractor,"67 model yr I believe that will intermittently lose power cut out and die. After waiting a while it may run ok for a while and do it again. In the past dad always thought it was a fuel issue and would drain the sediment bowl and would maybe help, maybe not. I cannot see any sediment in bottom of fuel tank. He has removed the factory fuel pump and is working off gravity now. So my question...Is it possible the factory fuel pump or a 12V electric pump would fix this or do you think more likely could be a coil issue?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
