Posted by pete 23 on July 23, 2013 at 11:06:39 from (74.47.41.165):
In Reply to: 1456 blowing fuses posted by MaverickM23 on July 22, 2013 at 14:42:31:
Dead shorts blow fuses instantly. A corroded or overloaded fuse holder will get hot and melt fuse ends, not blowing the element itself. Fuse must not get hot to work.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
