Re: Farmall 706 gas or diesel
Posted by caseyc on July 23, 2013 at 13:53:33 from (75.102.189.131):
In Reply to: Re: Farmall 706 gas or diesel posted by Johnston on July 23, 2013 at 13:27:35:
I may be wrong but I believe the 282D will fit just fine. It's the 310 German that is longer.
It comes down to how you use it. A 263 gas is a good engine and will make more power and start reliably over the 282 diesel. Down side is the gas consumption under heavy load. The 282 is very fuel efficient by comparison. The 310 is the best way to go, but then you need longer frame rails, longer sheet metal and everything else.
Casey in SD
