Posted by Owen Aaland on July 23, 2013 at 14:15:36 from (216.47.32.133):
In Reply to: 1456 blowing fuses posted by MaverickM23 on July 22, 2013 at 14:42:31:
Five lights is usually pretty much the limit for the fuse holder with a 20 amp fuse. With six lights you usually have problems. Changing to a 25 or 30 amp fuse usually just results in melted fuses.
One of the mechanics I used to work with would add a second fuse holder behind the dash wired in parallel with the one in the dash panel. My preferred method is to add a relay with a 30 amp breaker and use the switch and original fuse to control the relay.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
