Re: M band brakes
Posted by CNKS on July 23, 2013 at 15:08:22 from (216.144.104.128):
In Reply to: M band brakes posted by DV on July 23, 2013 at 14:12:02:
I don't understand the pedal clearance for the "new" band, if it fits right (some don't) you should be able to reduce the clearance. However the ones that don't fit are usually too tight and can't be loosened. The spongy feeling could be oil on the band.
