Posted by pete 23 on July 23, 2013 at 19:00:58 from (74.47.41.165):
In Reply to: farmall 400 diesel posted by Ed in Pa on July 23, 2013 at 17:34:25:
Fifteen gallons of Hy-tran (or equivalent) in transmission, & final drive. Pto rear unit is separate and also requires two quarts Hy-tran. Pump uses same oil as used in engine and just fill to level petcock. If pump leaks some diesel into pump you will want to check oil level before each time you use it and depending on how much it leaks, drain it down or change it often. Only holds a cup full.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
