Re: 1456 blowing fuses
Posted by Owen Aaland on July 23, 2013 at 19:57:19 from (216.47.32.133):
In Reply to: 1456 blowing fuses posted by MaverickM23 on July 22, 2013 at 14:42:31:
Run a wire from the battery cable connection at the starter to a 30 amp auto reset circuit breaker. From the circuit breaker go to the common load terminal on the relay. From the normally open terminal run a wire to the lights. That is the power circuit. For the control circuit use the wire that is on the switch that is currently going to the lights you want to control and connect it to one of the relay control terminals. Connect the other control terminal to ground.
When you turn on the lights power will flow through the control circuit in the relay to ground which will cause the relay will close the normally open contacts. Power will then flow from the starter through the circuit breaker, through the relay, and on to the lights.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
