Posted by gene bender on July 24, 2013 at 10:09:17 from (67.55.198.105):
In Reply to: BN split posted by fredmich on July 24, 2013 at 09:31:51:
Ive split many there you do need to be able to roll one end apart best if its on wheels. After moving apart a few inches then you can unhook the drive shaft from the yoke coming out of the tranny. Or remove two blots on the u-joint. I would also replace the bearing. You also need to remove the bolts holding left brake and clutch pedals as that shaft goes thru the bell housing and the tranny cant move until they are loose from the platform as they will slide apart along with bell housing. I can do it in two hrs but i do have wheels to let one end roll apart.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
