In Reply to: BN split posted by fredmich on July 24, 2013 at 09:31:51:
Fred the last time I split My BN If I recall correctly I split it at the engine. and the prop shaft just pulled out of the clutch / fly wheel. Splitting it at the back of the prop tube housing you have to deal with the throw out bearing. It may seam simpler to split it at the back I didn't think about it just worked from the front. Sling and support the engine. If you have an equipment mounting bar ( cultivator bar attachment) for the front or can make one that will assist in supporting the front of the tractor and keep it upright. The back / tran and rear end the rear wheels will keep steady just set on an makeshift bench or roller cart. >> Two places the leak may be the lower 1st.2nd 3rd 4th shaft it is just a cap with a shim and seal pack use good quality auto gasket maker; the upper is the input prop shaft there check the oil seal and shaft face //if worn use a speedy sleeve to repair the shaft if needed. **** see other's comments and notes about these. also use auto gasket maker to reseal flange. Best to you work safe. Wm.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
