Re: 300 utility oil pressure
Posted by The tractor vet on July 24, 2013 at 12:38:53 from (75.19.124.38):
In Reply to: 300 utility oil pressure posted by nj tom on July 24, 2013 at 08:03:38:
IF it is down that far then it is past time to pull the crank and cam . have the crank mic,ed and install new cam bearings and a new oil pump . I believe you will find that the crank is out of round and wore down and will need turning on the mains and rods . Once that is done then it should be good for the next fifty years.
