Did this problem occur over time or did it come about after having the clutch out?
If the clutch was out and now cannot be adjusted correctly the disk is probably on backwards. If it occurred over time look for worn release bearing and/or carrier or worn out clutch levers and pins.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
