Posted by Owen Aaland on July 24, 2013 at 16:54:05 from (216.47.32.133):
In Reply to: 450 battery cooked posted by P and R Pete on July 24, 2013 at 16:34:32:
Two possibilities. Either the battery failed internally and caused those cells to over charge or the alternator has failed and over charged the battery causing a battery failure. The voltage coming from the alternator should not be over 14.5 volts if it is 15 or mare the alternator is the problem. If the charging voltage is Okay then the most likely cause is a battery failure,
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
