Re: Farmall 350 TA clutch questions
Posted by mkirsch on July 25, 2013 at 05:26:13 from (64.80.110.75):
In Reply to: Farmall 350 TA clutch questions posted by Oregon Tractor Jack on July 24, 2013 at 07:08:10:
The TA clutch will wear out if the TA is adjusted wrong, if the main clutch linkage is pulling on the TA clutch linkage all the time, for example.
What you are looking for is the tractor to HOLD with the clutch pedal halfway out on an incline, in a forward gear, with the TA lever ahead. It should not roll backwards down the hill.
If the tractor tries to freewheel down a hill with the TA lever ahead, the TA clutch is likely shot.
It's not a major deal to replace, but it does require splitting the tractor at the bell housing.
