Re: My 444 won't stay running except on starter fluid.
Posted by aleuicius on July 25, 2013 at 08:01:30 from (98.24.136.222):
In Reply to: My 444 won't stay running except on starter fluid. posted by scprotz on July 25, 2013 at 07:37:01:
If it runs on SF, two things come to mind. 1)something is plugged in some fashion - junk, or adjustments or 2)a gasket/seal is leaking air.
Since you"ve cleaned it (if cleaner passes thru those 90s and any screens, I"ll assume it"s clean), the problem might be limited to adjustments - like float clearance and "jets" - or reused gaskets.
Re-check adjustments and use new gaskets
