Re: My 444 won't stay running except on starter fluid.
Posted by El Toro on July 25, 2013 at 11:44:58 from (108.3.218.181):
In Reply to: My 444 won't stay running except on starter fluid. posted by scprotz on July 25, 2013 at 07:37:01:
Hold your hand over the throat of the carburetor while a helper makes an attempt to start the engine. If there's not much suction on your hand
it's an indication of low intake manifold vacuum. Also do a compression check and post the readings.
Spray some of that starter fluid in the area where your intake manifold mates to the engine block and see if the engine fires while cranking. You will need a helper. Hal
