Sitting inside or outside? May need to check for water mixture in the fuel tank, air cleaner, in the crankcase and above the pistons. Remove the spark plugs and see what comes out when cranking the engine if it will turn. Check the compression to see if it has stuck or bent valves or bent pushrods. You must at least have a cracked carburetor or manifold or a bad gasket.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
