Re: Farmall H spraying water and gas PLEASE HELP
Posted by DaninKansas on July 26, 2013 at 09:14:02 from (24.248.193.103):
In Reply to: Re: Farmall H spraying water and gas PLEASE HELP posted by sflem849 on July 26, 2013 at 06:24:31:
Agreed.
But if the engine is turning over (just not firing) while it blows water out the exhaust it doesn't sound like its in too bad of shape.
Turn it over a few more times to get the rest of the water out then pull and dry the spark plugs (clean them too while you're at it). Shoot a little WD40 in the spark plug holes to dry out the cylinder and try starting it again.
