Re: Farmall 1952 Super C electrical system questions
Posted by Bob M on July 26, 2013 at 12:58:34 from (69.207.86.200):
In Reply to: Farmall 1952 Super C electrical system questions posted by den67 on July 26, 2013 at 12:36:31:
The voltage regulator your SC now says it's been converted to 12 volts. Ground polarity now could be either way, depending on the whim of whoever did the conversion. (From the factory it was 6 volt, positive ground)
A couple ways to determine polarity:
1 - Check the voltage regulator. Some (not all) VR's are designed for only one polarity. So ground polarity MAY be marked on the cover.
2 - Drop in a good battery and connect it for POSITIVE ground. Now turn on the ignition or lights. If the ammeter deflects to the left (indicating discharge) it is wired positive ground. However if it deflects to the right it is negative ground.
Once you've determined the ground polarity and completed your wiring, good practice is to polarize the generator before the 1st start: With the battery installed and the engine stopped, briefly jumper the BAT and GEN terminals at the regulator. Soon as you've made contact your generator is polarized.
