Re: replacing rings on f20 and cant get piston back in
Posted by Janicholson on July 26, 2013 at 19:49:59 from (74.60.94.18):
In Reply to: replacing rings on f20 and cant get piston back in posted by chummymatt on July 26, 2013 at 19:33:04:
Measuring the end gap is critical. .004 to .005" per inch of bore is needed. This can be greater for the scraper rails of the oil ring but not less. If a one piece oil control ring, it is the same. If the oil ring is 3 piece, a very crisp lower edge is needed on the ring compressor to assure a clean entry into the bore.
A little cleaning up of the top edge of the bore with 300 grit paper to give it a tiny round edge can also help the transition into the cylinder. Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
