Re: Cub Voltage Regulator
Posted by Janicholson on July 26, 2013 at 19:55:48 from (74.60.94.18):
In Reply to: Cub Voltage Regulator posted by WI-Ed on July 26, 2013 at 19:27:59:
If 12v, charging volts should be 14 to 14.6v at 3/4 throttle. If 6v, 7 to 7.4 is good. Use an analog (needle type) meter, or an expensive averaging digital, to make the reading across the bat terminals. Jim
