Re: Farmall H spraying water and gas PLEASE HELP
Posted by SDE on July 27, 2013 at 07:25:06 from (174.124.43.71):
In Reply to: Farmall H spraying water and gas PLEASE HELP posted by Haschen on July 26, 2013 at 02:57:52:
I like to play with this type of "project tractor". If you do to, buy it. If you are thinking that you can skin this old man and make money off him, then walk away. You are over your head and will look like an idiot trying to re-sell it or fix it.
SDE
