Posted by mazemeister on July 27, 2013 at 10:24:22 from (69.127.90.15):
In Reply to: Re: IH 966 posted by notjustair on July 26, 2013 at 19:35:13:
OK let's clarify a few things here. Adding a turbo in and of itself does not add any stress to the machine. it will still only develop as much power as the load on it requires. even if you put a load on it, you only get (much) more power if you also increase fuel delivery!
No matter how much you increase the fuel, that is the max setting! the pump will only deliver the increased fuel if you put an increased load on it.
if for example you take a stock 806 that is set at 95 HP and put a turbo on, then set at 95 hp again, you will probably end up turning the pump DOWN, have cooler exh temps but still have the same torque at the flywheel at a given load.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
